garisilver
I built a custom fountain. The water splashes, so I installed a water supply for make-up water. I ran almost 50' of 1/2" ID reinforced tubing from the house supply and installed a float valve in the sump to maintain the water level.
It's been working great.
Recently, I bumped into the specs on the float valve. It says the max pressure is 10kg, which translates into 22psi.
The house pressure feeding it is about 65psi.
Even though it's working, I'm concerned about the pressure causing the float valve to fail. Does the 50' run of tubing drop the pressure at the valve? If not, can I install a pressure reducing valve, adjust it to 20lbs, and still have the float valve work properly 50' away?
Thanks in advacnce
Thanks in advacnce
