Floor plan help/suggestions?
JoeJee
HVAC Contractor
Arkansas
I’m about to hire an architect or draftsman but wanted to get as much of a layout done beforehand. It has been suggested that the kitchen be closer to the garage but not sure how that would fit. This is a second floor addition that is separate from the 1st floor.
- WS pipe is from lower floor and can’t be moved.
- The greyed out spot between 35’-43’ can be included in living space for dining. This can’t easily be done closer to garage.
- South (bottom of page) overlooks a valley/field and will have a lot of windows. North side looks at dirt hillside.
This has 5’-9’overhangs on North, South, and West sides. 16” on east side.
- 8’-9’ ceilings depending on type of flooring system we will end up needing.
Tuttles Revenge
Not sure how you can get the kitchen any closer to the garage as they seem to share a wall.
The shower at Bedroom 1 looks like a squeeze to get into and may be impossible to have a shower door work next to the sink. Might swap the toilet to that location and move the shower to where the toilet is drawn.
Bedroom 2 bathtub I would normally see against the exterior wall with the toilet next to it and the sinks next to that. But you need 24" in front of a toilet for clearance either way.
Kitchen triangle between Sink - Stove - Fridge looks good
Inside door to the garage? Make it not interfere with the bathroom door. A door to the garage make it convenient for groceries and bringing salt to the softener.
Will you have an attic with storage? Drop-down stairs are nice, instead of a hatch that needs a ladder.
