Fleck 5600sxt will not draw brine, technician is scratching is head! Help!
Chris Sexton
London, UK,
I am sorry to hear that, but I understand the need for a working softener. It would be interesting to try poking a flexible probe in from the injector cover area to make sure that there is a path into the manifold during BD time.
Thanks, I will try that.
Bbersch
Humboldt
You're a genious! The problem was not the screen or the injector but the cavity where they sit. I removed them and flush water through the housing and surprise... BD draw seems to be back! What a good feeling! Thanks a million for your help! John
Can you explain further of what you did here? I'm having this exact same issue. Are you saying you took out your injectors and injector screen then put the little cover back on and ran it through a cycle quickly to flush it out?
