T>D>C
Great Site!
I stumbled across you guys while investigating a problem that hopefully is not too common. Approximately a year ago we found drain flies in the bathroom. I traced them to wet organic material in the slab opening around the bathtub drain. When the toilet is flushed water runs underneath the slab into that area. Pulled the toilet off the floor and discovered that the builder had missed with the wall and could not install the toilet so they moved the flange away from the wall by cutting the connecting line leaving a gap. I picked up some concrete like mix from the hardware store (can't remember type - recommended for application from hardware store and was supposed to be water proof) formed a nice smooth transition filling in all gaps and painted it with enamel. Recently the toilet started leaking again, and I discovered the material I used had fallen a apart, apparently from exposure to water. Please look at the attached picture and make a recommendation. You can see where they whacked off the PVC pipe (white jagged edge).
Thanks in advance for your help.
