Petermet
I am building a house in Indonesia and have a 45 meter deep well.
I currently use a charcoal filter (1054 tank) and a resin softener (also 1054 tank). I don't drink this water.
For drinking I use a small RO unit into plastic 5 gallon containers.
In the new house I would like to be able to drink from the tap without risk and propose to add Ultrafiltration (0.01 micron) and UV sterilisation. Given the lack of mains sewer systems and the cheap concrete septic that many houses use I want to be safe.
Does this seem like a sensible set up or overkill with both UF and UV?
What would be the recommended order of filtration (charcoal, UF, UV, Softener)?
At what stage should I tee off the water for the hot water, or leave for all stages?
Thank you for any advice which unfortunately is not available in Indonesia (or at least near where I live)
