GMrules
I have 13 station Hunter ICC with Hunter Valves
None of my stations will turn on, I wanted to run by you guys the procedure I was planning on following to isolate any potential wiring issues
-- From clock
Measure voltage from the common to each position on the modules, whats the expected voltage? AC or dc?
Measure the voltage across the transformer, 24 Volts I assume? What happens when you ASSUME?? :^D
I am thinking I have a common wire issue or clock issue as nothing works
In the field
- Whats best way to Ohm out the common wire?
- Is it possible to have common wire short to ground?
- I bought 500' roll of wire I was going to twist one end on the common in the clock and then pull it to furthest value and ohm it out, good bad Idea?
- would open between values cause all then to fail I woudl think not as long as we have return path to the clock
Best way to verify wiring between valves?
_ expected voltage at he value?
TIA
George
-- From clock
In the field
TIA
George
