Hi,
I'm on well water with a pressure tank, and pressure ranges from 40-60psi (pump on-pump off). I'm installing an Aquapure Model CWS200ME water softener. For a drain, I have two options:
1. punch a hole out of the basement wall and dump the water (via an air gap) into a nearby roof downspout drain that ultimately discharges down the hill from me. This is convenient but probably not to code, and might kill off some trees I have down that hill.
2. Go up 4ft in elevation, run within a soffit in the basement exactly 45 linear feet, and then drop into the washing machine drain which goes to a drywell.
The instruction manual says:
1) 1/2” ID up to 15 ft. when discharge is lower than INLET.
2) 5/8” ID up to 15 ft. when discharge is slightly higher than the INLET.
3) 3/4” ID when drain is 25 ft. away and/or drain is installed overhead
I'm not opposed to running a 1"dia pex tube this long (45ft) distance. But would appreciate any experience in this issue.
Thanks
Theodore
Thanks
Theodore
