I had to solder on a ball valve at one of the lower points of my house, and even after purging, draining the water heater, and waiting three hours, water was still coming out.
I used an air compressor to blow water back up stream (had all faucets open, and used at a low psi), and that gave me about ~5 minutes of time until water started coming back out at the solder point.
Whether that was a smart or dumb move is debatable, but it worked!
I was able to successfully complete the job, but noticed erratic pressure behavior at the faucets a week later. I checked the expansion tank and it had no PSI, but also no water come out.
I filled the tank back up to match the water heater PSI, and has maintained PSI with the faucet pressure fine for over a week now.
How is this possible?
How was the expansion tank able to "fail" and displace all of that air without busting the diaphragm? The air couldn't escape through the nipple, right?
Should I play it safe and replace the tank, or just see how it goes?
