I'm installing a second thermal expansion tank. This is for my fire sprinkler system. I'll have 100 feet of 1" copper in my attic, with a storage capacity of about 4 gallons, so am installing a 2 gallon Bell & Gossett PT-5 tank.
The tank will be installed in the basement utility room stubbing of off what could be considered a riser (the sprinkler system is comprised of mostly all 1" line in a looped system; there are four 1" "risers" to the main floor and two to the attic).
Bell & Gossett write that the tank should not be installed at the dead end of a branch, which is precisely where it's going.
I'm trying to figure out the reasoning behind this. As my attic pipes are gradually warmed during the heat of the day, I expect pressure will build steadily across the system, and the expansion tank will serve its purpose.
Similarly, my pressure relief valve, which is located outside at the service entrance just beyond the back flow is effectively the dead end of a branch (assuming no water flow because my house won't be burning).
So any opinions on this edict?
