Electric water heater closet
Mark- DFW
Dallas -Ft Worth
I need to add an electric water heater closet for a bathroom remodel. The access door would be in an adjacent den area. Other than sufficient clearance for removal, does the door need sealing at the bottom, a lock, or anything else beyond a simple pre-hung hollow core door with a latch/knob?
I'm in the design phase so still flexible on the solution. Thanks for any help.
If necessary, it does not even need a door, since it is NOT a gas heater. If it were, there would be a LOT of restrictions, including you might not even be able to install it there.
Phog
Active Member
Rochester NY
You'll want to plan space adequate to have a water heater + thermal expansion tank + drip pan. Other than that, nothing special needed. If it's possible, it's always a good idea to have a nearby drain to connect to the drip pan (especially if there are finished areas on lower floors underneath where the water heater lives).
Sarg
Enjoy Learning
Upstate New York
Here's my "closet." And it's been a PIA for 40 years.
