Egress window well drain Code Question
DCA430
Seattle
Hello. First time post.
I'm installing an egress window for a basement bedroom remodel addition. My basement is a little over 7 ft below grade. I've dug a 5 ft x 5 ft x 5 ft hole. Just next to the window I have a downspout that collects secondary roof drainage to a cast iron storm drain pipe, which ultimately drains into the home's shared waste/sewer pipes.
I've been reading the UPC storm drainage code, but I still have a question. Can I tie into the cast iron storm drain pipe (with a trap) to have an egress well drain, rather than divert the water with a pipe to the footing drain pipe?
Thanks in advance!
Mel
For the information of others, in old parts of Seattle, the roof drains may share with the sewer lines. Normally in new developments, those are kept separate.
Sylvan
Still learning
New York
Older building code we use to use a combination sanitary and storm trap but the storm water had to be trapped and at least 40 pipe diameters upstream of the sanitary trap connection (4" pipe 13'+ upstream) possibly to prevent loss of trap seal during a major rain storm
