Easy Tub to Shower Conversion
sajesak
United States
I am about to purchase a home, but I wanted to get an idea of how much it would cost to convert the bath tub before I proceed.
The house has a 1950s era bathroom that has a tub only. I wanted to do an easy conversion to a shower (that doesn't involve breaking into the wall) until I have enough money to renovate the entire bathroom. I have seen products that is a new faucet with a diverter with a wall mount. This would be perfect (and I think I would be able to handle this project) however, this bathtub has a shelf that the fixtures come out of. The shelf protrudes from the wall too far that I would not be able to mount the pipe flush to the wall. Also, the wall is tiled all the way to the ceiling.
I have attached some pictures.
If this is going to be a costly or time consuming project, I'm going to pass on this house. Because the shower situation would need solved before I moved in.
Any advice??? Help!
sajesak
United States
If this is going to be a costly or time consuming project of easy entry tub cut, I'm going to pass on this house. Because the shower situation would need solved before I moved in.
Any advice??? Help!
thanks in advance for any help
Id love to help but its too much time, there are no pictures, you could be where plumbers charge 100 an hour or 400 an hour.
Its all part of a normal sale to have inspections, bring a contractor in get a bid ? its simple
Tuttles Revenge
I think what you're asking for is a replacement tub spout that has a shower hose attachement.
This is one example HERE
I would be concerned that the shower surface wasn't designed to be water proof for a shower.
I thoiught he was removing a bath tub . but i think you got it right Tuttles ! maybe some FRP on the walls to bring it in on budget .
