I'm having issues with a slow well. I haven't had any problems until the last couple of weeks. I have a low flow rate and am unable to maintain the pressures that I used to get. I used to have at least 50psi with one of my sprinkler zones on (that's what the cycle stop valve is set at) but that on that same zone I'm currently getting ~28psi with the sprinklers running.
I have a 1-1/2 hp pump of unknown type and age. I have a 6" steel casing. The well depth is 112' and the static water level is 12'. There aren't any new wells in the area. I have a 25' deep house well nearby with a jet pump and the flow rate from that is currently fine. I get a small amount of sandy sediment through the pump. The water is somewhat hard, leaving white mineral deposits on showerheads and such, but we don't need to soften our water.
The well was deepened in 1997, and that may well be the last time the pump was replaced. The pump controller I replaced a couple of years ago was dated 1981.
Any thoughts on what to look at? Is my best bet to call the pump company out (I don't think I'm up to pulling the pump myself).
Thanks
Thanks
