Philip E Agne
I have a drum trap under my bathtub. I run cleaner through it all the time because I cannot access the bottom of it because it's on a slab. Even if I could take the cover off there would be no way to access the bottom of it. I am considering just cutting it out and replacing it with the P-trap. Problem is I'm not sure if I can hook into the old lead lines. There is one going to the main drain and another going to the vent. I have no desire to remove all this lead since I cannot even see where it connects to the main line. I have no desire to redo the drain vents. Can I get away with using rubber couplings on both sides? I'll try to post pictures later.
