Venting Outdoor Grease Trap - Trapzilla!
Chesterbrook
I am looking at having an outdoor grease trap installed in a parking lot. The installation instructions specify a vent be installed at inlet and outlet, as well a recommend the vessel is vented. These vents would be 2".
This seems like a lot of vents since this will be installed with a manhole cover on top.
The parking lot is in front of the building. I've attached a photo of the area that we've excavated above the lateral where the interceptor would be installed.
My thought is to combine the vents into one 2" pipe and run it vertical next to the building. This is cleanest solution I can imagine. I don't like the idea of doing this right next to the building but we cannot leave an exposed pipe in a parking area / walkway.
1. If you were doing this would you just bring up the vent from the concrete or maybe do a very short stub and connect the rest of the vertical with a fernco? I'm worried this is going to get knocked and need repairs.
2. Would you bring this up next to the building OR a few inches out and use a hanger mounted on the wall? I don;t want to impede access to the masonry for future work.
Been reading this community for years and have gotten much good guidance. Thanks for reading and relying.
Id put it on unistrut against wall with a no hub band a foot off ground for removal . how high and termination Id have to think a bit more about might have to go all the way up
Chesterbrook
In case there are fellow grease trap enthusiasts here - the manufacturer has told me that the vessel should be vented indoors for odor, otherwise just the outlet is vented. I was mistake in thinking they specified a vent on inlet and outlet.
Although they have an install drawing showing a vent at grade doing this in parking lot/walkway makes me nervous.
Plan is to tie vessel and outlet vents together and run next to building, supported with unistrut. Jeff, agree the fernco is a good idea. Might see if we can get approval to have a sheet metal guy make up a faux getter to hide this thing. Otherwise the vent is getting sprayed with Krylon.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Big outdoor grease interceptors are all the rage here in the Bay Area. I'm concurring with Jeff H Young. I'd use thin unistrut up the side.
Breplum
Simply run vent to near grade and put inside/cover with an appropriate Christy box with finger holes for air...metal, drive-over capable.
