Drip leak between PVC storm drain pipe and cement roof/ceiling
GregoryHP
DC
Hello – I’m a DIY homeowner (recently renovated 1895 row house in DC) and struggling with a small leak in my garage (brick walls, cement ceiling with a patio on top/roof). The patio on the roof has a storm drain connected to a PVC pipe that goes through the roof of the garage and carries stormwater to the rear alley. There is a PVC elbow immediately below the ceiling that drips water on the floor. It appears that storm water is seeping between the cement/concrete ceiling/patio floor and the PVC pipe. The source of the water is hardly visible, but this drip can fill half a bucket with one heavy storm. This leak has already ruined may painted garage floor, so I’m eager to repair the leak before replacing with a better flooring solution. I’ve read a lot about similar issues (usually in basement walls vice garage ceilings) but there doesn’t seem to be a consensus. Solutions that I’m considering include epoxy, caulk, and cement. I’ve read that caulk is flexible and will adjust with structure but that it’s a superficial and will fail. Epoxy is rigid and the watertight seal will break over time. Cement is also a superficial repair and that water will still work its way through over time.
I’m thinking that maybe this requires a combination of materials? For example, 1) apply band of hydrophilic paste/adhesive around edge of pipe where it touches the cement ceiling; 2) then pack hydraulic cement around the entire PVC elbow; and 3) apply epoxy adhesive where the edge of the cement meets the PCV pipe. Or is this overkill?
Also, what would be required for surface prep? I’m guessing that I should just clean the cement surface, and then sand around the PVC pipe?
Also wondering if I should reseal the exterior drain on the patio cement floor? The contractors used a PVC bell drain for some reason. Not sure how the flanging around the drain is sealed to the patio floor. Looks like the patio was recovered with a thin overlay. There’s already some cracking where the overlay meets the plastic bell drain.
I’m pretty handy and should be able to repair it myself, but need help identifying the correct material/solution first.
Here’s a list of products that I’ve ready are effective:
Quikcrete Hydraulic Cement (w/ foundation sealant?)
Polyurethane construction adhesive (high viscosity, wet and dry surface, fills hairline cracks, stretch)
Quikcrete Construction Adhesive
3M 5200 marine adhesive/sealant
Loctite Concrete crack ad masonry polyurethane sealant
Epoxy Sealant
Quikrete Epoxy Concrete Repair Sealant
Silicon caulk
Liquid Nails Clear small projects silicone adhesive
Butyl rubber sealant
Rubber spray seal
Rust-oleum leak seal or Flexi-Seal
Expanding foam
Urethan Grout injection (liquid expansive foam)
DAP Watertight Roof Sealant
DAP Watertight concrete filler
Plast-Aid Repair Putty
Would appreciated any advice folks can offer!
