Greetings,
This is my first post here, although I've browsed this forum many times in the past for information.
Let me get right to my question.
I have an old brownstone, in Brooklyn, NY. On the main service line there are two dresser compression fittings. One between the pressure regulator and the meter and the other on the pressure release line.
Here are some photos.
Somewhere else on this forum I came across the information that these dressed fittings are usually used for temporary repairs. I've owned the house for 9 years and there were already 2 inspectors here the looked specifically a the gas lines and said nothing about those fittings. There's no leak, no other problem.
Do those fittings perhaps have to be there, by some old code?
Or if those were temporary fixes, am I eventually required to remove them?
I would like to frame the basement walls, to put insulation, so before those gas pipes get buried behind new sheetrock, I would like to know if it would be best to have these couplings replaced by solid pipes.
What do you think?
Thanks...
What do you think?
Thanks...
