Double sink DWV check
clix
Missouri
I tore out a double sink vanity that was in my basement bathroom and will be moving the bathroom sink to an adjacent wall, making the bathroom a little bit smaller and adding a wetbar where the old double sink used to be. My current plan for drain and venting is in the attached, red is the drain for the bathroom sink, blue is the trap arm for the wetbar sink and the green is the shared drain and vent. This is my third "plan" with the prior iterations being much more complicated (almost embarrassingly so), so I'm looking for any reasons why this plan won't work.
To my eye, the thing that is most concerning is the number of turns the shared drain portion makes. Is that problematic? The pipe coming out of the floor will be encased in a box inside the cabinet, I'm wondering if I should add a cleanout in that area given the number of turns. I could also add a cleanout above the blue and red san-tees as I will have open access from the back side of the wall.
Any thoughts or suggestions appreciated.
clix
Missouri
So, I have simplified a bit to avoid the extra turns for the wetbar sink, which I think makes a better layout. In the prior drawing, I was worried the trap arm for the bath sink would be too long, but with the revised plan, the trap should only be about 36" long, which is under the maximum length for my AHJ. The currently existing pipe in the picture is going to be cut below the stacked san-tees.
Is this layout acceptable/better than the previous? Any particular fittings I need to use or places I should include a cleanout?
