Double 3/4 bath venting double-check
Stereo
Colorado
I am remodeling to create two new back-to-back 3/4 baths (though the same-type fixtures are not back to back). I have been unable to grasp horizontal wet vents so I've changed up my layout to incorporate traditional venting. I know my pipe sizes so I haven't listed those, but I would greatly appreciate a check of my venting layout since I do have some vertical wet vents in my plans that I'm not 100% sure about. Please see the attached drawing.
Thank you very much.
  • Plumbing_dry vents.pdf
Stereo
Colorado
plumbing_dry vents.jpg Sorry. The pdf isn’t loading. Here’s an image. CHANGE: Rather than a santee where the horizontal branch enters the waste stack, should I use a wye + 1/8 for easier snaking?
A good inspector would reject your "left hand" toilet because it is NOT vented due to the right hand one flowing past it, cutting off air flow from the "vent" nearby.
Stereo
Colorado
So I need a dry vent to come off the WC drain before it connects to the horizontal Waste branch? Just curious though; isn’t it assumed that some air always exists in the upper portion of the drain line since that’s what makes horizontal wet drains possible?
