Hi all,
I am installing my shower valve and volume controls and need to use a tee to split the supply after the thermostatic valve to provide service to the shower head and hand shower.
Does the orientation of the tee matter if I want the shower head and hand shower to have the same flow rate when both are turned on?
The tee can be oriented so that the water flows straight through to the showerhead and branches off to the hand shower, like so:
My intuition tells me that the lower resistance of the straight-through path to the shower head would result in the shower head having greater flow than the hand shower when both are turned on, but I don't know this for sure.
The tee can also be oriented so that the water hits the "dead end" of the tee and flows left to the shower head and right to the hand shower, like so:
This orientation seems like it would result in equal resistance to both the shower head and hand shower, which would result in equal flow, but installing the tee in the latter ("dead end") orientation will require me to make several 90-degree bends in the supply line to make the connections thereafter, so if it doesn't matter, I'd prefer to go with the first option.
Thanks for reading!
Thanks for reading!
