Do Pedestal sump pumps need a weep hole?
Dee2
New York
When installing my Pedestal sump pump should I drill a weep hole? And If so, I am thinking it should be above the water line and below the pump motor, yes? thanks
Dee2
New York
I just joined this group and I am testing to see if I have my account set up correctly because no one has responded yet and I need to replace the pump today.
Sylvan
Still learning
New York
Above the pump and below the check valve. Ideally Drilled at a 45 DEG angle so the water will shoot DOWN inside the sump
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
I have never drilled a weep hole and never had to. Mind you, I don't use a check valve but rather let the discharge line drain back into the sump pit. That way I don't have to worry about standing water in the drain line freezing.
Sylvan
Still learning
New York
You must like short cycling of the sump pump . Most sump pumps are installed in a heated area
Sylvan
Still learning
New York
LLigetfa
NW Ontario, Canada
I have the float setup so that it runs a minimum of 60 seconds. I could set the float much higher but that would cut into the 4 hours it typically takes for the level to breach the top of the pit. During Spring thaw the pump runs about once per hour and when raining really hard, every fifteen minutes. I monitor and trend it with software. 2:00 AM was when my iron filter backwashed.
The pump is in a heated area but the far end of the discharge pipe where it breaks to the surface is outside.
The discharge pipe goes down below the footing and continues (below the frost line) to slope down until it turns vertical to the surface, so it is only a portion of the short vertical section that drains back into the pit. The entire run is insulated including the vertical where it breaks to the surface. I keep good snow cover over it.
