SAS
I noticed (or actually my wife noticed) that the pressure switch was clicking on and off every time the water was used. Following some instructions on the web, I drained and charged the tank. The tank is a Flotec FP7120-08 and the switch is a 40/60 so I charged it to 38 PSI (according to the instructions on the tank). Now everything appears to be working properly.
On my first attempt to fix the problem, I turned off the pump and released the pressure by opening a faucet and then charged the tank. That improved the cycling time, but it was still cycling the pump every 2-3 gallons. Draining the tank, as I mentioned above, seemed to be necessary. Is that indicative of a problem with the tank? In other words, have I fixed the problem or merely put a band-aid on it?
