Hi all.
I've been lurking for a while now and have seen some excellent advice. I'm hoping for some more experienced insight on this situation that's put a hold on our DIY renovation of our bathroom.
First time bathroom renovaters. The tub is set in place, drains line up, mortar bed beneath, and attached to studs. Started putting up the drywall and discovered that....it doesn't line up on the left and right sides with the flange, for some reason.....
Left side has the plumbing. In the picture, you can see that the drywall overhangs the flange. Based on other things I've seen in these threads, that's fine - I can replace that piece of drywall with one that runs down to the tub deck. Back of the tub is basically in line with the flange and rests on it.
Right side is where the real problem seems to be. Currently, the flange is well in front of the drywall. The drywall is in line with the rest of the wall. That wall runs to the door and the door trim is tight in the corner.
Is the easiest solution to build out the right hand wall from alcove to door enough to be even with the tub flange? The original plan was to tile halfway up the wall and then to the ceiling in the tub alcove.
Thanks for any ideas or feedback.
