Delta R22000 vs R11000/10000 combo
jtcircle6
Oklahoma, USA
Good afternoon,
I am in the process of remodeling our master bath and have a question regarding the shower setup.
New shower will have shower head, rain head, and body sprayers. All will be plumbed with Pex A.
My question is what is the difference or advantage of utilizing the Delta R22000 vs the R10000/R11000 combo? I can't seem to find a direct comparison of the two different setups.
I would obviously want max flow and temp control and wasn't sure if one was better than the other.
Thank you for your help!
Jeff
diy-montana
I'm investigaitng the same choice, and my research has pointed that from a cost perspective, R10000/R11000 combo is the least attractive option. The diverter valve and trim costs are much higher than I would have thought. I'm leaning towards two independent R10000s or the R22000
John Gayewski
Iowa
The r11 and 10000 are for use with a tub filler. The r22000 are for shower heads only.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
In my experience, you cannot mount the valve upside down...the cartridges insert specifically into the v index of the valve body, and then all the handles are designed to go on only one way.
John Gayewski
Iowa
The cartridges are now reversible. They used to be that way, but now it doesn't matter which side is hot or cold or if you have them back to back the cartridge can go either way.
