Deep sink p trap with garbage disposal issue
Slav Pakhnyuk
Blaine, WA
Hi everyone,
Remodeling my home and I had new countertops installed as well as a deep center drain under mount sink.
The existing drain in the wall is in the center of the cabinet as well as is the sink drain.
I did a p trap mock up (didn’t cement anything down yet) and wanted to check with you guys to make sure everything seems ok before I permanently install the threaded adapter and the 45 degree elbow.
My only concern is the tail pipe going to the sanitary tee in the wall is slightly sloped down away from the wall towards the p trap. It’s only a tiny bit but thought I’d mention it.
I’m trying to avoid opening up the wall to lower the drain. Any advice would be greatly appreciated!
When you lay a level from B to A, what does the bubble do?
James Henry
Billings, Montana.
You can build your own trap but their still may be the problem of water sitting in the bottom of the disposal.
Slav Pakhnyuk
Blaine, WA
MACPLUMB
HOUSTON, TEXAS
#1 YOU CAN CUT THAT G/D 90 DOWN A COUPLE OF INCH'S AND THEN YOUR TRAP WILL FIT,
#2 BE AWARE THAT WITH YOUR TRAP THAT WATER WILL SET IN THE BOTTOM OF THE G/D
WHICH WILL CAUSE EARLY RUST OUT OF THE GRIND CHAMBER
Slav Pakhnyuk
Blaine, WA
Guys check this out. This is a mock-up of using the lower clean out for the p trap. Also I routed it to the other side to conserve more space. It fits nicely with the insta hot tank on the right side anyway.
Is it a problem that the clean out doesn’t have a sanitary tee? It’s just a sharp drop.
You disposer drains at 6.6" below the sink.
The Insinkerator 3/4 hp Evolution series drains at 6.0" below the sink. That might help.
