Dead leg
Netmouse
NJ
A plumber left two short "dead legs" when he cut pipes to the tankless coil that was removed when a hot water tank was installed. The attached image is of one. He put a cap on the end of the cut pipes, instead of removing the pipe back to the main pipe. It just seems lazy. I read a lot about NOT allowing dead legs of any length as water stagnates and can grow bacteria. I complained and he now has faucets on the ends so I can drain the pipes, which seems odd. I think he felt it was too complicated to totally remove the pipes. It this an issue? Should I just get another plumber in here to do this differently?
Jm66208
Kansas City
Not the end of the world, but to me it's just sloppy lazy plumbing. Not so much leaving that dead leg, but screwing what appears to be a steel cap onto that sharkbite fitting. He could have cut most of that dead leg off & soldered on a cap in about 5 min. or spend another 5 min & replace that copper tee with an elbow.
It looks like he did not want to install another hanger so he just cut the pipe past the one that was already there. If it concerns you, just remove the cap/faucet and cut the pipe off as short as possible and reinstall the cap on your new stub. There is no problem with a "short" dead end, just very long ones.
Netmouse
NJ
Thank you! Appreciate your feedback. It seems OK if nothing more is done.
