Alco
I will disagree with most when it comes to angle stops. I have not and will not use 1/4 turns regardless of the construction. They are the same as they were in the early 80s ''non serviceable" , in fact I have seen them leak from the seal at the handle. I only use brasscraft mulit-turns, that which I can service if replacing it leaves me no option. A wire brush, grease "which I do on all my new stops" and a brass stem rebuild kit and "see ya at the beach"! I remember when Brasscraft only came with brass stems which dates me I guess. Nonetheless I am Brasscrraft till I'm dead.Posting this question to Terry's Forum..... currently finished installing a trial set of Dahl ball valves after being disappointed with all the junk sold locally. This includes BrassCraft,Nibco and Watts which eventually will not shut off water or eventually drip when I must perform maintenance or faucet replacements. The worse ones are the plastic stem with rubber washers which all drip when I attempt to turn off water to replace a failed supply side ceramic cartridge. It's gotten so bad I avoid these types completely however even the BrassCraft, Nibco, and Watts quarter turn ball valves also leak or drip. I've now started using Dahl quarter turn ball valves but thought I would post a question to the forum asking if there were "quality" quarter turn ball valves (preferably forged versus junk cast yellow brass) undersink shutoffs sold. I read it now normal and customary to replace both the shutoff valve whenever you also replace a kitchen or bathroom faucet. My concern is the main house gate valve shutoff is old and one day I may not be able to turn water back on after performing repairs or maintenance. Your thoughts?
