Cycle Sensor Question
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by HighPointFarms, Jul 18, 2021.
  1. HighPointFarms
    HighPointFarms New Member
    Jul 18, 2021
    HVAC
    Kansas City, MO
    Hello all!
    I want to start by introducing myself. My name is Jon and I live in central Kansas and have been stalking this site for a long time and figured I’d ask a question.
    I had a small pond dug on my property this spring and was in need of a way to keep it full between rains. I have an old well on my property that was drilled back in 1991 and only produces 2 GPM or so that used to serve the house and my shop before rural water came through then it sat unused for about 20 years. I put a pump down it when I moved in. I use it still for the shop bathroom and for watering trees.
    I had a new well drilled by my pond last week and I’m getting about 4-5 GPM out of it now. It is 120’ deep with a static level of 35’ and the pump placed at about 110’. I planned on putting a windmill on it and using Mother Nature to keep the swimming hole filled for “free”. Here are my questions:
    1) I’m going to get a Cycle Sensor installed on the pump I just put down in the new well and let it develop for however long it takes. The well drillers guessed at least 10 GPM when they were blowing it out with air. Can I just set the CS to restart after say an hour and just let it keep bouncing off the dry pump shutdown? Will that hurt the pump?
    2) I have seen a combo submersible/pump cylinder setup and was wondering if anyone has had any experience with one?
    I feel like I’m rambling so I will end it here, but I want to thank everyone in advance for your responses. This site is a GREAT resource!
    Jon
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Sure you can let the Cycle Sensor develop the well for you. Might not even have to set the timer for an hour. Try 20-30 minutes first, and if the pump runs for more than 2 minutes when it comes on, the delay timer is set the way you want it.
    Yes you can put a submersible on the end of a windmill pump barrel. A lot of ranchers do this so they can have water for the cows on calm days or when the windmill isn't working. I love regular old windmills, but they are not free. The windmills themselves are very expensive these days, and windmills require regular maintenance. Replacing the leathers every year or two, checking the oil in the gearbox, and even replacing the ball checks on the pump barrel are regular maintenance items.
    I have just a submersible in my stock water well and it hasn't shut off in over 19 years so far. Running 3 GPM to the stock tank all the time. Cost me about 40 bucks a month electricity. But I will gladly pay for the power not to have to climb that tower and pull those rods ever couple years. Big ranches like the 6666 that I have worked for are now using solar power pumps as even they are more reliable and easier to work on than a windmill.
    HighPointFarms likes this.
  4. HighPointFarms
    Jul 18, 2021
    HVAC
    Kansas City, MO
    Thanks fr the reply, Valveman! I actually bought an old 8’ Baker windmill off Facebook marketplace a year ago and plan on restoring it. I love the nostalgia of an old mill, just spinning without a care in the world.
    I will be in touch with you very soon to get a cycle sensor ordered. How long does it take to ship to KS?
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    I have an old windmill for decoration at my house. But don't try to keep it running. Shipping is usually 3-5 days.
  6. HighPointFarms
    Jul 18, 2021
    HVAC
    Kansas City, MO
    I
    I will order one here shortly!
    Thanks!!
  7. HighPointFarms
    Jul 18, 2021
    HVAC
    Kansas City, MO
    Just ordered it. Thanks again for the info Cary!
    Jon
    valveman likes this.
  8. HighPointFarms
    Jul 18, 2021
    HVAC
    Kansas City, MO
    Just out of curiosity, can you draw water with a cylinder pump THROUGH a submersible pump? Dean Bennett Supply sells a sub pump with cylinder on it but uses a tee and a foot valve. I would think with the small amount of water being drawn by the mill it would be fine to pull through it. Am I correct to assume that?
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
  10. HighPointFarms
    Jul 18, 2021
    HVAC
    Kansas City, MO
  11. valveman
    Mar 15, 2006
    Lubbock, Texas
    That is hilarious! I have never seen that. No you don't need the foot valve thing. The windmill pump barrel will draw water right through the submersible and the check valve on the submersible.
  12. HighPointFarms
    Jul 18, 2021
    HVAC
    Kansas City, MO
    Thanks for the response Cary! I figured it would be okay to draw through the submersible pump but wasn’t sure.
  13. HighPointFarms
    Jul 18, 2021
    HVAC
    Kansas City, MO
    I got my Cycle Sensor installed this evening! Fast shipping and super easy to program. Hopefully it will help my new well develop nicely. I have it set to lock out for 31 minutes after the well is dry then the pump kicks back on and runs for about 15 minutes and then shuts back down on dry mode. It will also get my pond filled back up!
    Thanks, Cary
    Jon
Similar Threads: Cycle Sensor
Pumps and Tanks Well Forum & Blog. Water is life. CYCLE Sensor, float switch, well pump, Stenner wiring? Jul 12, 2021
Pumps and Tanks Well Forum & Blog. Water is life. Question about cycle sensor from CSV Mar 24, 2020
Pumps and Tanks Well Forum & Blog. Water is life. Cycle Sensor Currents/Storage Tank Jan 26, 2020
Pumps and Tanks Well Forum & Blog. Water is life. Cycle sensor Apr 27, 2019
Pumps and Tanks Well Forum & Blog. Water is life. Cycle sensor to detect burst pipe. Sep 21, 2018
