Curious about insulating walls
tomcola
tomcat
CT
I have built a room made from my deck. I don't want it as a room only seasonal. I would like to put some foam insulation between the 2x4 'S. How do I attach rigid foam? One inch ?
tomcola
tomcat
CT
If I fully insulate it it would be considered a room by the inspectors. I only want it as a screened in porch. If I call it sa room it will raise my taxes. And I would like to know how to hold it in place, glue?
construction adhesive, but if it is a "screened room" what good will insulating the walls do? The room is going to be at the same temperature as the outdoor air. It should only be a "room" if it is closed in with doors and windows, so it could be occupied year round.
tomcola
tomcat
CT
It would be considered a room. A screened in porch does have windows and doors. Without those it would be useless to call it a screened in porch!
Cacher_Chick
Test, Don't Guess!
There is adhesive specifically used for installing extruded foam board. It is commonly found in caulk-gun style tubes in the same isle of the store as caulk.
Most other adhesives have solvents in them that will melt the foam board.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Around here a screened porch has only screens, not windows.
Foam board can also be held in simply by a friction fit if cut oversized. It can also be held in place in vertical applications with pieces of lath cut long so that it bows.
Keep in mind that many foams are required to be covered with a fireproof material (typically drywall). Some of them burn quite hot and give off some noxious fumes. You don't want it just sitting there on the walls uncovered.
And, if it truely is screened in, not sure if insulation would buy you much of anything.
quotes;I only want it as a screened in porch. A screened in porch does have windows and doors.
It has SCREENS for windows/wall openings and SCREEN DOORS, (if necessary, not all SCREENED rooms are where you need to, or can, exit from them), for exit. You are being argumentative or do not recognize the difference between SCREENS and SOLID windows and doors. SOLID window and doors create a temperature differential between the indoors and outdoors, and insulation DOES minimize transfer between the two areas, and when necessary the MORE insulation the slower the heat transfer occurs.
DanT
ohio
insulating a screened porch is just a waste of money but hey it's your money.
