Steveleewonder
- Messages
- 25
- Reaction score
- 0
- Points
- 0
Hi Terry,
I read all 5 or 7 posts here about cu301...
my cu301 has no light in the front cover, so I opened it and checked out the ribbon cable's connection and it looks like ok, then I saw 1 red light and 3 green light "blinks", +24V overload, +24V, +10V, +5V, and another green light and yellow light blink on "control indicator" and "min. speed"
Of course no water supply in my house, just flashes on the LED and tik-tak sounds...I did turn-off and on breaker, but same problem...
In my case, my cu301 fault, right? this mean "DEAD"? and unrepairable?
I just used water to garden for 3 hours and then this happened....
If fixable, then can you advise for me...
Thank you so much,
oh! if not fixable, then how can I remove cu301 and just make the connection to pump and make it provide water...I don't need variable or constant, all I need is WATER..
thanks again
Thank you so much,
thanks again
