Robert Smith
We had some strong storms blow through yesterday afternoon but don't think we lost power as all the clocks are still set. We did, however lose internet for a period of time and I'm dealing with network problems as a result but in the mix of it we suddenly lost water to the house. Literally I had a faucet running and it just stopped abruptly. I checked to see if anyone was using anything else but found that the Grundfos CU 301 was dead. No lights no nothing. I checked the breaker and checked the power supply to the controller with a non-contact tester and it appears to be getting power but no lights on the outside or inside of the controller.
After we got internet back I discovered how this is not uncommon and apparently these controllers don't typically last that long. I also saw that they sell for around $500. So I have some questions (follow-up details on my setup below:
1. Can I jumper the pump to get some form of water until it's fixed?
2. Difficulty of installing an alternate, cheaper, hopefully more reliable system (CSV1A)?
3. Turned my boiler off; should I keep it turned off until water is fixed?
My well line comes into the wall of my basement then to the pressure sensor, into the expansion tank, out to a pressure gauge with a shutoff valve then onto a radon tank with another shutoff valve right before it. I don't see a valve to isolate the line from the well to the house but if water's not being pumped in, is that an issue? I was reading a good long write up about installing CSV1A and it mentioned turning off the water to the house. I can do that, just not until after it gets to the tank.
Right now we're calling places to get prices on the remote control box and have a call into a plumber for replacing it. We're also going to contact the well service shop that, I think, installed the unit to see what they can do. One way or another, I don't see this thing getting fixed today (that's why I want to try to bypass the controller for water) so we're also looking for motels to stay in. My breath is a bit stale at the moment haha!
Thanks in advance for the help.
