Cricket Game Crashing - Need Help
sajesak
United States
Hey all, I've been facing a rather frustrating issue with my favorite cricket games recently, and I'm hoping to get some guidance or solutions from the community. Whenever I launch the game, it crashes without any warning or error message, leaving me clueless as to what might be causing this issue. I've tried a few troubleshooting steps such as verifying the game files, updating my graphics drivers, and running the game as an administrator, but the problem persists. It's becoming a real buzzkill, especially when I'm eager to immerse myself in a thrilling match. My system meets the game's requirements, and I've never had any issues with it until now. Has anyone else encountered a similar problem, or does anyone have suggestions on what might be the root cause and how to fix it? I'm open to any advice, whether it's tweaking in-game settings, checking my hardware, or anything else you think might help. Your input is greatly appreciated, and I hope we can collectively solve this crashing problem so we can get back to enjoying some quality cricket gaming. Thanks in advance for your assistance!
Honestly, when my game kept crashing, I just ended up killing time watching cricket streams and messing around on https://mostbet.com.pk/ until I finally figured out the fix
Hey, I’ve run into stuff like this before and it’s super annoying. Since you’ve already tried verifying files, updating drivers, and running as admin, a few other things that helped me in the past:
Close background apps/overlays – Discord, Steam overlay, GeForce Experience, etc. Sometimes they make the game crash before it even starts.
Check your DirectX / Visual C++ Redistributables – Even if your system meets the requirements, a missing or corrupted package can cause instant crashes. Reinstalling them fixed me once.
Corrupt config or save files – Try renaming the config folder (usually in Documents or AppData). The game will make a fresh one and that sometimes stops crashes.
Event Viewer – If you open Event Viewer → Windows Logs → Application, you might see an error at the time of the crash. Could give a clue if it’s graphics, memory, or something else.
Hardware/temps – Even if specs are fine, check CPU/GPU temps. Overheating or failing hardware can crash games immediately.
If none of that works, sometimes a clean reinstall helps—especially if a patch left some weird leftover files. Also, running the game in windowed mode or lower graphics settings can at least help figure out if it’s a graphics issue.
