Cracked acrylic flange
Johnlard
Los Angeles
I cracked our acrylic tub’s flange. It won’t be a cosmetic issue due to the backer board and tile but will there be structural issues? Can anything be done to repair this to maintain structural integrity (eg epoxy)? Thank you.
Weekend Handyman
Active Member
Nova Scotia
I am not a plumber or pro of any kind. It take your question to mean "Will this crack spread and cause a problem?". To me it looks like you just chipped off some of the acrylic. I had a bit of the acrylic chip off when I installed my tub (not nearly as much as yours). There are companies that repair acrylic tubs. However, I would contact the manufacturer for direction. My guess would be that they will say to leave it alone, but they may indicate you should have it repaired. Either way, I would follow their advice.
I expect that flathead deck screw was not the right kind of screw to use without a washer -- for others who may be planning.
Weekend Handyman
Active Member
Nova Scotia
I was wondering if it was a failure to pre-drill or the use of a screw gauge that was higher than recommended.
Maax installation guide says "No 8 x 1 1/4» screws (4.2 mm x 32 mm, Flat or Phillips head)". I don't believe they mention washers. I have only ever installed one tub, so I don't know what the other manufactures specify.
WorthFlorida
Solutions
Orlando, Florida
I looked around for the correct screws and it seems to be a mixed bag. First a hole must be drilled. then use a pan head or flat head screw such as https://www.lowes.com/pd/Teks-8-x-1...-0V9BZFyzJLmu9sqkMBoCCBsQAvD_BwE&gclsrc=aw.ds
If you leave that deck screw or hardie board type screw, the tub may eventually start to crack by leaving the screw in there. The screw head gets wider and that is what caused the damage. The wall studs will swell and shrink with seasonal changes in humidity putting more or less stress on the screw head.
Interesting.
This would be a Phillips head without the countersink aspect. Other Phillips would be made for a countersunk hole I would think they would want to specify that aspect.
Johnlard
Los Angeles
Thanks all! That is exactly what happened. We used deck screws. We will be removing the deck screws and using the flat-type screws. I’m more concerned with the acrylic continuing to crack and and wondering how to mitigate this risk (if any). Silicone vs calk? For some reason my second cracked photo didn’t show. See attached.
Modulerics
New Jersey
How did this turn out?
