Connecting shower drain to 2" copper pipe
Ray McAllister
I am having a shower replaced with a new wet bed shower. After the demo, we discovered the drain pipe is 2" copper. The tile guy needs a 2" PVC pipe to connect to his drain. This is in a 3rd floor condo with cement floors with no access from below. The pipe is roughly flush with the top of the cement floor, with about 2" of clearance between the outside of the pipe and the cement floor opening. How do I go from 2" copper to 2" PVC, or is there some type of shower drain that is mad for this type of connection? I found this adapter, but little information about it. Has anybody used one of these?
https://www.wingtite.com/products/c...ain-pipe-installations-require-a-pipe-adapter
John Gayewski
Iowa
The other thing to tell you is call a plumber. The tile guy should not be hooking up pipes.
