genmaster
Hi all,
I'm installing a 20kw generator ( residential) and connecting to LP gas using 3/4" CSST. My question is, do I still need to use the 14" piece of flex line supplied with the generator or can I connect directly with the csst? There will be an isolation valve between the gen and the gas line. Not sure if the csst is ok with the vibration, although the supplied flex line is basically the same material. Thanks
