I am connecting a 3” closet flange into a 3 “ ABS drain pipe. The fitting is loose not tight. I’m afraid that if I use ABS cement it won’t seal. Is there another way other than using ABS cement? I found that Lepage Pl700 can be used fir ABS.
The gap is about the thickness of standard size paper
Okay. I would glue it, screw it, and put my name on it. While the “weld” the solvent is supposed to create likely won’t happen, the solvent will still fill that tiny “paper thick” gap and keep a seal. The screws to the subfloor will keep the flange in place. You’re fine, go for it.
The only correct way to adhere an abs fitting to abs pipe is to use abs solvent.
