Tphilly12
Our current well produces only 2 gpm. Purchased a 2500 gallon tank and it is placed about 100 feet away from the well and about 8 feet lower than where the current well head and pressure tank are feeding home.
My questions:
1. Do I need to run the power from my current well pump to the storage tank in order to be able to have some kind of float switch to turn it off when tank is full? What do I need?
2. Can I use a booster pump to pump from the storage tank back to the well area where the pressure tank is and just connect to that current system? (disconnect well waterline and bring to tank, waterline from tank gets connected to current pressure tank?)
3. Assuming I have to disconnect the power from well pump that goes to pressure switch and run new power from booster pump at tank to pressure switch?
4. What is best, submersible pump in the storage tank or is exterior booster pump ok? I was thinking a 3/4hp? Servicing 3 bdrm/3 bath 2000sf home
Any help appreciated. Don't know what the electrical hookups look like for (i) the well pump to talk to a float switch and (2) the booster to the pressure tank system (just use existing?)
My questions:
