David Pecnik
Hello to everyone,
I'm at my wit's end on this one, probably because I have done so much research, I've overloaded on it.
Here's my situation. I have a 1 1/4" tubular PP drain pipe that I need to attach to "in the wall" what I believe is a 1 1/4" steel pipe. The OD of this steel pipe I measured at 1.66" and an inner diameter of around 1 1/4". I need to connect that plastic drain pipe to the steel drain pipe in the wall, but I'm not sure of what size coupler to purchase. At first, thinking the steel pipe was 1 1/2", I ordered a reducer nut and washer that went from 1 1/2" to 1 1/4". However, the nut turned out to be too wide. When I tried screwing on a 1 1/4" nut on the steel pipe, it was too small. So I next ordered a flexible coupler 1 1/2" to 1 1/4"--again the 1 1/2" end was too big. The 1 1/4" end, fit over the pipe. I'm now at a complete loss as to what measurements I need in a coupler to allow me to make this connection.
Any guidance would be greatly appreciated!
David in OH
David in OH
