Compression Fixture Stops - Replacement Parts Universal
Weekend Handyman
Active Member
Nova Scotia
Hello:
I just would like to validate something I believe to be true. Generally speaking, would I be correct to say that the replacement parts for for compression style fixture stops are universal.
Specifically, I am referring to these parts: https://www.homedepot.ca/product/brasscraft-repair-kit-for-multi-turn-stops/1001386569?rrec=true.
Mr tee
Montana
My father used to say that the only thing standard in plumbing is that everything is oddball. That kit should work if your stop is the same brand, it gets doubtful after that.
It's safer usually, to remove the compression ring, and if the nut was overtightened, you may need a puller to do it. That also lets you change the nut, which may be corroded so it matches the new valve.
Weekend Handyman
Active Member
Nova Scotia
Thank you, it's actually a crimp fitting. The valve type is compression (i.e. vs ball).
Weekend Handyman
Active Member
Nova Scotia
My father used to say that the only thing standard in plumbing is that everything is oddball. That kit should work if your stop is the same brand, it gets doubtful softer that.
Thanks. For $4.oo, I will give it a try. Based on what you are saying, I will also pick up a new one at the same time so I have a solid plan B.
Tuttles Revenge
I don't think the OP was asking about the compression side of the angle stop, but the stem, packing, washer. I think they all look the same, but some of the threads on the packing nut may vary. I never repair them however since in our remodel work we are installing new stops to switch them all over to ball style.
But I have found several different compression types on angle stops. The location/depth of the copper where the ferrule rests is the key difference. Most use the same threads but I have found one older style that didn't.
