Closed Loop Hydronic heating system
GabrielGab
montreal
An old heating system with an electrical Hydra 15 boiler ,water being sent throughout a pump to a piping network on the second floor of a duplex. The problem that i experience is upon firing, i get the thermostat to click and start the heating. A loud "popcorn " like noise it's going on on the start up and the frequency /pace slows down and eventually disappears.
I don't think I have any water velocity issues , the banging and popping could mean kettling problems?
Is the water inside the boiler flashing to steam due to the boiler’s inability to pass the heat into the water, and to have the water carry the heat away before it superheats.
I do not have any flow device installed but there is flow, the water gets out and up to the upstairs radiators that are hot
Insufficient flow?
Is the water overheated inside the boiler, and isn’t moving fast enough, for the amount of heat being generated by the boiler?
I believe that the pump is moving water.
There is no other strange noises like hissing, whining, screeching.
Really appreciate some help/suggestions. thank you
John Gayewski
Iowa
Sounds like a heart exchanger could be plugged/ full of crud. I'd give a good douching
