Clog drain
Geo422
Cin oh
the drain for my washer has been running slow and clogged up at times. Today I had it scoped and the service man said there was a clean out plug 12 feet down inside the pipe causing the trouble.and his auger would not bring it out.
Is there such a thing as a claw that can grab this item and remove it? If not the concrete would have to be torn .
Some drain cleaners with big machines have an array of cutters.
I don't know if it would be removable, or if it would have to be chopped up. What size pipe is being blocked?
James Henry
Billings, Montana.
I've had a vacuum truck from a septic tank cleaning company vac a clean out plug from a drain for me with success. I've also taped a stiff wire on the end of a section of snake and bent it into an ell shape and sent it down the drain along side of the camera snake and dragged the obstruction out.
Geo422
Cin oh
Floor drain pipe house is from the 1940s
