Clean Out Help
MattW24
Seattle
I am in the Seattle area and I have a question regarding clean outs.
I have a basement that is plumbed separately through a back water valve due to being below the upper man hole cover on the street. The toilet is the upper terminus of the basement drain line. It runs approximately 3 feet horizontal then goes through a backwater valve and connects to the horizontal main drain through a Wye. The main horizontal drain has a 3” clean out upstream.
The basement toilet does not have a clean out. I am hoping that since it’s less than a 5’ run before joining the section that has a clean out I am covered. But the code also says you need a clean out at the upper terminus. Does that trump the 5’ exemption rule? The vertical vent on the toilet is 2” so I can’t install a clean out on the vent. Am I code legal?
Any help would be highly appreciated. Thanks.
Your "backwater valve " has no cleanout?
Note that if your valve has a flapper, those leak. Plan for that.
MattW24
Seattle
The backwater valve has a sleeve that runs vertically up to the slab. I imagine I could un-thread and remove the valve and use the opening as a cleanout via the sleeve. There would still be the 3 foot section from the toilet to the backwater that has no cleanout. Does that make sense? I can draw a diagram.
MattW24
Seattle
Here is a crude diagram. I’m concerned about the section from the toilet to the backwater valve not having a clean out since it’s an upper terminus of that drain line. But it’s only a 3 foot section until it passes the back water valve and meets the main horizontal drain that has clean out access.
Sylvan
Still learning
New York
A fixture such as a toilet can be used as a CO . Also Rigid and some other drain cleaning companies have a closet auger with a longer cable
General has a RAM Jet ( pneumatic ) that has a toilet cone you can use for stoppages without the fear of having a cable caught in a backwater valve
MattW24
Seattle
Thanks for the reply. I have read that you can pull a toilet to snake the line. I didn’t know about the pneumatic clean out method. That sounds cool. However I don’t think that pulling the toilet is an acceptable substitute for a required clean out in Seattle.
I was hoping that since the distance from the toilet to the backwater valves is less than 5’ I won’t need a clean out at the toilet end of the line. I just don’t know if it matters that it’s the upper end of that particular drain line. I want to make sure it passes inspection then in the future I can always pull the toilet to snake the line if that very short section backs up.
I am not a plumber. I expect you are OK cleanout wise.
What is the lowest drain on that 2 inch horizontal? Floor drain? Shower? Whichever, I would put a loud flood alarm there. Replace the batteries on a schedule. When the alarm goes off, stop using water upstairs and investigate.
There are backwater valves that are pretty good. They are "normally-open". The older cheaper check valves, now often adopting the name backwater valves to sound like the good kind, are normally-closed flapper valves. They reliably leak after a few years. Solids block the flapper from seating fully.
If your low spot is a shower, you could have a utility pump that could pump the leaked sewage to an upstairs drain such as a toilet. The pump might be able to overcome the leakage, and then some if the water is from the sewer main. If the water is due to a block in your line to the main, then the pump would not help much, if at all.
MattW24
Seattle
The lowest fixture is a shower which drains into the 2inch line. Good idea on the alarm. I will look into that. The back water valve is just a simple flapper on an ABS fitting with a sleeve for access. It imagine it could easily fail.
