Claw Foot Tub: Direct Drain
Konakid
Michigan
New homeowner here...of a house built in 1900. I am remodeling our upstairs bathroom and installing a claw foot tub. Due to the drain plumbing, and the fact that I can't change its position, I have to use a direct drain.
Is there a way to use a nice aesthetically pleasing brass drain, and attach it to the pvc I used to replace some of the old galvanized drain pipes?
Konakid
Michigan
What do you mean by "direct drain", because that would have different meanings? We attach brass drains to PVC/ABS drain systems regularly.
Water would travel straight down into the drain pipes. Instead of traveling out and then into the drainage system.
I wasn't sure if that was what you were referring to, (did its price give you sticker shock?" It is also called a "toe outlet" drain. Just install a "trap connector" to your PVC and slip the outlet tube of the drain into it.
