Reicherb
I have a Well-McLain Series 3 P-D--7 boiler that I believe to be original to the house which was building in 1968. At the end of last winter I discovered that the circulation pump was running constantly. It's entirely possible that it's had been running for the two years that we lived here. I'd been trying to trace down high electrical use for a while.... I traced it down to be a zone valve that kept returning to the open position after I manually turned it off. As the heating season was almost over I simply removed the wire from terminal 2 on the zone valve and put the valve in the closed position until this weekend.
I replaced the valve and then the valve would stay closed until the thermostat called for heat. when it stopped calling for heat, the valve would not close. I traced that down to be an improperly wired thermostat. I corrected the wire and now the valve opens as closes as it should.
Now however, the circulation pump seems to never stop. It's been running about 5 hours now. Before moving the wire on the thermostat, when I manually put the valve in the closed position, the pump would turn off after a few minutes. If I kill the power to the whole system and turn it back on after a minute or two, the pump starts right away. The water temperature is still about 130 degrees (it's warm outside) so I'm thinking maybe this is normal and it will stop when the water cools off. Is that how it should operate? I'm concerned that the pump really should not be running when all 3 of the zone valves are closed as there is actually no where for the water to go...
If it's not operating correctly, any ideas what might be wrong? I've reviewed the valve and the thermostat documentation and believe they are wired correctly.
Thanks,
Brad
Thanks,
Brad
