Charlotte 3" long 1/4 bend
Clutchcargo
USA
There seems to be a design consideration built into this bend. Any idea why one side of the 90 is different than the other?
Using this below a WC to go to horizontal.
Tuttles Revenge
The exterior shape has nothing to do with the interior geometry of the fitting. Just a weird external design.
I suspect it is easier to remove from the mold that way. I am picturing maybe a 3-piece mold with the piece forming the inside radius being withdrawn toward the right of your photo. If there was a hub on the right that looked like the one on top, that would interfere with the mold piece being withdrawn.
Clutchcargo
USA
I thought maybe it was designed this way for added strength or something along those lines but you're probably right, something to do with manufacturing.
John Gayewski
Iowa
The exterior design can sometimes be a factor. There are fitting with "nubs" built in to help with assembly. They give you something to grip and push against. With this particular one I'm not totally sure. It's possible there is an intent, but it's not evident.
