Changing textured ceiling finish to smooth finish.
sc.homeowner
South Carolina
I'm a new member so this question may have already been addressed. In this area eveyone refers to it as "popcorn ceilings". I know it's very messy and requires a lot of preparation, but I' retired so my labor is free. Home was built in '85 so I don't have to worry about the asbestos issue. My concern is mostly about room ceilings that have been repainted (sprayed with latex) and is there a commercial solution to accelerate the removal! Appreciate your feedback if you have experience with this process.
If it's been painted, it can be really messy to clean off. If you go to a good lumber yard, you should be able to find 1/4" drywall...I'd slap some of that up rather than trying to clean all the old crud off and fix the divots you make in the process.
For areas that haven't been painted, A spray bottle filled with plain water works. Spray it on, let it sit for a moment, then scrape it off. Works pretty well...I did about 500 sq ft in a few hours.
Statjunk
DIY Senior Member
The 1/4" drywall with really long screws and a whole lot of glue is the way to go.
Otherwise prepare to scrape like an animal. It will likely never look right.
Tom
CharlieM
Iowa
You would have to scrape it off either way I'd guess. Glue won't do much good with the heavy popcorn.
Charlie
ceiling
Run the scraper over the painted ceiling. It should take enough of the high spots off so the water can penetrate into the popcorn. It is not even enough for 1/4" sheetrock to make a level ceiling.
Statjunk
DIY Senior Member
Guys,
I've seen this done before several times. Granted the guys doing the work were professional drywallers but it comes out perfect. On one of the jobs I lived in the house for 2 years before selling it. So it didn't come apart.
They punch a bunch of holes in the ceiling to find the studs and mark the ceiling. They glue the board with thick beads, use long screws set the boards. After setting the board they glue gaps as necessary.
I think they did knock off some high stuff but I wouldn't say the knocked off much.
I'm about to have another one done this way but it's a spanish swirl and not the usual popcorn.
Tom
Squ1rrel
Texas
This stuff should help to loosen up the popcorn:
It's supposed to work on painted surfaces too.
Jimbo
San Diego, CA
Just remember that if this is old, it may contain asbestos. Here, if you de-popcorn it is required to submit a sample for asbestos test. If it is asbestos, you have to have the guys in the white suits come in and do it.
