Cast Iron XH vs NH sizing / Charlotte / NewAge Casting
djfremen
Seattle
Hey Gang,
I'm scratching my head with old school XH. I have a 4" XH pipe around 90 years old. I want to cut in and fernco a No-Hub Wye to ABS.
On the buying website it doesn't say XH but instead
Charlotte NH 00020 1800 Pipe 45 deg Wye-Branch, 4x4x3 in, Spigot, Cast Iron, Black, Domestic
Item #: NHYPPM Brand: Charlotte UPC: 611942002184
So, I then checked out Charlottes
Catalog and only see XH with hubs.
4 x 4 x 3 in. Spigot x Hub Extra Heavy Cast Iron Wye
Part #XHYPPM | Manufacturer Part #XH 00044 1400
It looks like ID is smaller on the nohub.
They don't make XH version just NH... Thoughts?
Sylvan
Still learning
New York
Rather then using a Fernco I would strongly suggest a mission coupling
djfremen
Seattle
Well, not thrilled with the mission clamp or the standard Fernco
There's a mismatch with ID.
Be rid of the P1066-44 P1056-44 and replace that with a banded coupling. I suggest you measure the pipe ODs with your long-reach digital caliper. There are a lot of sizes offered.
Do warm up to the one with the purple label if it fits.
djfremen
Seattle
Tuttles Revenge
Your old cast iron pipe had no defined outside dimension when it was manufactured. Outside dimensions were not necessary because each fitting was made from inserting a roughly the same outside dimension pipe into a roughly dimension fitting hub and the void filled with lead. Sometimes you will have to use a banded coupling that is specified for a different diameter makeup than what you think you're using it for. Only new pipe has standardized outside dimensions.
