Hey guys, i have a question about a vent that i saw today. the sanitary wyes used were installed backwards (running upstream) which seems like it would restrict air flow. Is this plausable?
Air is a gas the moves because of pressure differences, NOT GRAVITY, which means it works a lot different than water. For esthetic purposes ONLY the fittings are installed differently than if they were in a water drain situation, meaning, if your terms "backwards" and "upstream" are used properly, the fittings are correct.
