Cast iron motor adpater cracked Goulds Motor Apapter Part#1K310
on02151blueline
Here is some info about the pump & motor:
A.O. Smith Model C48A94A06, SER 8G97, HP 3/4. Also on the A.O. Smith plate is: Goulds NO. J05853L. The cast iron motor adapter has part#1K310 casted into it.
I have a Goulds Jet+Plus pump that the cast iron motor adapter cracked. (I think my irrigation guy didn't drain it properly before winte:mad:)
I found the Goulds ITT manual by searching for that part number and want to order one and install it. My problem is that I can't figure out how to get the motor adapter off of the motor shaft. I have found, on this forum thank you, how to remove the impeller, but now I need to remove the spring looking thing that appears to be holding the motor adapter on to the shaft.
My other question is, now that I have the thing apart, are there any other parts I should replace? This motor/pump is pretty old, installed by the previous owner so I have no idea exactly how old it is. It is only used in the spring/summer.
And my last question is, when I am looking at the Goulds ITT manual I assume it is safe to say my model is a J+,right? Under the J+ series heading on the parts listing there are several columuns, J5 J5H J7 J10, J15. How do know which columun to get my part numbers from? I would like to replace the impeller, but there are four different part numbers listed under those five columns.
Thanks in advance for any help anyone could provide me.
Sammyhydro11
Massachusetts
That spring can be preyed out with a couple of screw drivers.Unbolt the motor from the pump casing and tap the edges of the pump end. It should pop off. I would replace the shaft seat along with a a new casing gasket and guide vain O ring. The area where the shaft seal sits in should be cleaned thoroughly and the porcelain and rubber should be lubricated with K Y jelly. The seal can be pressed in using a socket as well as the spring. When pressing in the porcelain ring be careful that you press it in evenly so the rubber wont tear.
Sammy
Pumpman
Pump Sales
So. Cal
That pump you have is a J7S, which is a 3/4 hp shallow well jet pump.
The spring thing is a mechanical seal, which is part number 10k10.
The stationary half of the seal is pressed into the motor adapter. It presses in very easily with your fingers.
You'll want to replace the seal ring, which is part 5K6, and the diaphragm, which is part 5K162.
Inspect the impeller (2K60) and guide vane (3K67) and replace them if you see any signs of wear or cracking.
Ron
Speedbump
Active Member
Riverview, Fl.
That seals generic part number is PS 100. You might find that easier than the Goulds number depending on where your looking. Any motor shop should have them.
So there actually is another use for K-Y Jelly!
bob...
on02151blueline
Thanks everyone for the very quick and very detailed responses. I will try getting that mechanical seal off tonight. I will also start looking for where I can order up the rest of the parts.
As for the KY, I will be certain to apply it as instructed. If you read my orginal post I belive it was my irrigation guys fault that the pump cracked as he did not remove the bottom drain bolt and it froze over the winter. When he shows his face again this winter, I will have mis-placed that tube of KY!
Thanks again everybody.
Tony
Sammyhydro11
Massachusetts
I think for now on i'm going to put some electrical tape over the KY label on the tube. You pull that out on the wrong person and they might think its party time in the basement.
Sammy
on02151blueline
Thanks for everyones help!
Just wanted to let you folks now I finally got my pump put back together. I found a pump shop clear on the other side of the country that I was able to order all the parts from, $174.00 total. Local pump shop wouldn't sell me the parts, would only do the work for me and charge me nearly what a new pump would cost. Most of the internal parts seemed fine, but I figured while I had it apart I would replace everything else. Put it back together and installed it yesterday and it works fine.
Thanks again for everyones help!
Tony
scott b
Goulds j15s
I had the same issue w/ my j15s. Where can I find the manual of a parts list for everything needed to replace the motor adapter, impeller, seals, and "spring thing"? Any help would be greatly appreciated!!!!!:
scott b
I found the manual at the link. Found all of the parts for $154.00! Thanks Again!
tinman28
New York
same problem
please help! i cant understand why the motor adapter cracked i drained it before winter and it is only 2 years old. Anyway can someone please help, i want to do this myself without going to a pump or machine shop. i got the pump taken apart but cannot figure out how to get the motor adaptor seperated from the impeller or the motor shaft. and i need to get the thing put back together. it seems as if you would need a press to get it back together?? i dont want to damage it. Thanks.
NHmaster
S. Maine
By motor adaptor are you talking the impeller housing? Because if that's cracked you might as well buy a new pump.
tinman28
New York
pics.
Guys here are a few pics of the problem i got, buying a new pump is a 500 dollar option but i would like to be able to change out motor adapter i can get one for 100 bucks. If i can unscrew the impeller how do i hold the motor shaft from spinning along with the impeller?? this pump is only 2 years old and it was drained before the winter i cant understand why it cracked.
NHmaster
S. Maine
500 bucks, boy they really hose you retail. VM is correct. take the back housing off and you can get to the shaft from there. be careful with the impeller if you are re-using it, it's easy to crack that also.
