Can I use a sanitary tee in these locations?
RJick
Oregon
yRYdjBV
Do I need a wye with a 45 or can I use a sanitary tee. I am trying to insert
a pdf but don't know if it is going through.
yRYdjBV
Thanks
wwhitney
Berkeley, CA
No pictures.
Sanitary tee is required when a horizontal trap arm turns into a vertical drain and a vertical vent take off.
Sanitary tee is allowed when a horizontal drain meets a vertical drain.
IPC may allow a sanitary tee on its back for a vent take off with the drain remaining horizontal; UPC requires a combo there, and I think a combo is better.
Otherwise use a combo (edit: for drains).
Cheers, Wayne
Why is that? Santee for venting is more compact.
If you have a cleanout in the vent pipe, I agree the combo makes it certain that the snake goes the right way.
wwhitney
Berkeley, CA
Primarily because I learned under the UPC, but also because if you have the room, why not use the combo? But I would consider a san-tee on its back for a vent takeoff if I ever did a project under the IPC and I needed the compactness.
Cheers, Wayne
Tuttles Revenge
Why: is because under the flood level of the fixture the vent must act as a drain in case the whole plumbing system backs up with waste. In seattle / king co. we can get away with a san tee on its back. just like installing a med 90 as a trap arm stub out rather than a long turn.
